minimum brake disc thickness??
Posted: Fri Oct 24, 2008 8:30 pm
by bobbyb1288
Hi Y'all
Does anyone know what the new and minimum rear brake disc thickness is for the 2005 1.5dci Sports Tourer?
Re: minimum brake disc thickness??
Posted: Sat Oct 25, 2008 5:05 pm
by DJC013
Hello, in my Haynes manual for my 2004 Scenic 1.9 dCi, they quote New discs at 8.0mm and Minimum thickness at 6.5mm, hope this helps, regards Damian.
Posted: Sun Oct 26, 2008 9:37 pm
by bobbyb1288
Many thanks but the disc appears to be greater than 8mm originally.
Posted: Wed Oct 29, 2008 8:31 am
by DJC013
bobbyb1288 wrote:Many thanks but the disc appears to be greater than 8mm originally.
Sorry about that, may be different for a Meg, regards Damian.
Posted: Wed Oct 29, 2008 12:00 pm
by A13XDT
https://www.renault.co.uk/Resources/PDF/ ... ins_UK.pdf2nd page of the pdf has got the car, brake disc diameter and thickness.
Alex
Posted: Wed Oct 29, 2008 8:45 pm
by bobbyb1288
Cheers Alex, just what I'm looking for. Bought the car from a dealer who sold me the car with rear discs at 8.15mm. They're going to replace them or I won't be happy. Will keep you posted if you're interested. Rob.
Posted: Mon Nov 03, 2008 8:17 pm
by bobbyb1288
They are 270mm diameter which means their minimum thickness is 9mm.
Posted: Mon Mar 15, 2010 7:46 pm
by mldd0
i have a 53 plate megane 1.6 16v looking at changing me rear disks and bearing would disks measuring 270mm x 10mm fit me car? there from a sports tourer 1.5dci on a 05 plate
Posted: Mon Mar 15, 2010 8:29 pm
by pw981
from memory, all Megane II saloon and hatch have 240mm rear discs, the sport tourers and scenics have larger rear discs.
Posted: Mon Mar 15, 2010 9:16 pm
by bobbyb1288
Sports Tourer has 270mm Diameter disc rotors, yours has 240mm so they wont fit. Might be possible to swap the calipers over assuming bolt mounting pitch is the same.
