megane 2 cooling fan not working
hi folks , i recently purchased a megane 2 dynamique 1.6 , i had an electric fault which caused the car not to start ! found the problem being the fuse board , i changed the fuse board and it cured the fault ,but since i changed the fuse board the cooling fan does not work !!!? i changed the fuse board with one from a dci which had a different part number , would that be the cause of the problem?
- WebCode
- Rally Driver
Re: megane 2 cooling fan not working
Yep it could be.. If one vehicle has climate control and the other only A/C then that could be root of the problem..
The UCH may just need to be reconfigured by your dealer using CLIP.. But I can't guarantee that would be the solution.
On the other hand it is more likely that the pinouts as different and as such will not work..
thank you for the info i will get it checked out at my renault dealer
Users browsing this forum: No registered users and 67 guests
