tyre wear
Re: tyre wear
There is an appropriate active thread at Parkers. In any case, check tracking first.
- Stranger
- Currently Drives:: BMW X1
Re: tyre wear
I believe that the inappropriate wear is due to the car set up i.e. in such as way as to handle better, be safer and all that. The standard fit Conti's are not at all good at handling this and many have found that when changing if you go for Kumho's they not only last longer but give better grip and reduced road noise.
If you do a search for Kumho you'll find a list of threads that'll explain which ones to go for
Re: tyre wear
Thank you for your advise
- Stranger
Re: tyre wear
I nearly forgot to say that Kumho's are a darned sight cheaper than Conti's too
Re: tyre wear
Not without a reason, I am afraid... See this
https://www.adac.de/Tests/Reifentests/default.asp
and this in particular
https://www.adac.de/Tests/Reifentests/So ... eID=174023
Kumho are still in the recommended category, but their wet performance is below average and I would not try them in winter.
Re: tyre wear
Cheers Alex
- Stranger
Re: tyre wear
I had them fitted them to my Megane II and have had them fitted to my OHs previous 2 Modus' and they will be fitted to my OHs latest Modus when the time arrives - far better than the Conti's in all aspects. My OH does 12 - 15k miles annually in all weathers and in all conditions in her job however, If you're at all worried by reports on the Kumho's lux then all I would say is avoid the Conti's and don't discount brands like Kumho, Falken, Hankook etc.
All the best
All the best
Re: tyre wear
Going to try dunlop sp 9000 now filled with nitrogen.... Any comment ?
- Gav
Re: tyre wear
lux175 wrote:Going to try dunlop sp 9000 now filled with nitrogen.... Any comment ?
I wouldn't pay for nitrogen inflation, seeing that air is ~78% nitrogen anyway, the benefits are miniscule.
Re: tyre wear
try using Rikens available from ats .,I got 12,000 on the set of four contis originally fitted with the rears wearing more than the fronts,with the Rikens I get nearly 15,000 out of the rears and 14,000 out of the fronts,car is 1500dci with 16"wheels.
- megane09
- Currently Drives:: renault megane '04 dynamique, silver, 17 nervasport alloys.
Re: tyre wear
ive got 17s on mine, with maxxis on the back and kumhos on the front and to be honest kumhos arent great, not really that good in the wet either, I would recommend avon theyre alot better more 'mid range' and better grip levels much better than dunlop and alot cheaper.
'04 Megane Dynamique, 17' nervasports alloys
Re: tyre wear
Nike on the left and Hush Puppies on the right...
megane09 wrote:ive got 17s on mine, with maxxis on the back and kumhos on the front and to be honest kumhos arent great, not really that good in the wet either, I would recommend avon theyre alot better more 'mid range' and better grip levels much better than dunlop and alot cheaper.
