Megane II expression 1.4 16v stats
Posted: Tue Aug 05, 2008 6:17 pm
by wolfie_d
hi, i was wondering if anyone would be able to give me the stats on a megane II expression 1.4 16v 03 plate? i wanted to know if its supposed to tell me when the tires are punctured, flat or the pressure is low. im aware that its supposed to show you on the little car diagram on the dash but i dunno if it does with this model. also, on the same diagram, when a door or the boot is open should it show a specific door, whenever a door is open on my car the whole thing lights up
Re: Megane II expression 1.4 16v stats
Posted: Tue Aug 05, 2008 6:53 pm
by Jonault
Only the doors that are open should be shown on the diagram. As for the tyre pressure sensors, look at the valves on the wheels to see if they have ordinary dust caps. It is unlikely that an expression would have this system fitted and if it had been done as an option when originally bought, you would notice unusual dust caps fitted on all the tyre valves.
Posted: Wed Aug 06, 2008 2:30 pm
by wolfie_d
thanks very much. anyone any idea how i could get the diagram to show which specific doors are open then? i know absolutely nothing about autoelectrics
Posted: Wed Aug 06, 2008 10:04 pm
by wolfie_d
thats what i mean though, it doesnt do that. how can i make it so that it does? a small complaint on my part but id like it to work
Posted: Wed Aug 06, 2008 10:30 pm
by keeforelli
hey
i have a 1.4 authentique 04 plate.....it literally lights the whole LED car up on the dash when you open a door. this is normal. higher spec and newer ones show more specific info. you're on to a loser here if you want more!!...need an upgrade!!!...but theres nothing amiss with yours.
