clunking car
jono35
clunking car
Postby jono35 » Tue Jul 29, 2008 12:03 pm
1.6VVT 52 plate 50k miles
Hello all
Yesterday driving home from work I noticed when I put the brakes on then accelerate after, there’s a clunking noise I think from the front end. Appears worse if turning right. I’ve jacked the car up and tried to move wheels and it seems ok. My question is. Is there any sort of test for the ball joints or engine mounts or does anyone have any other ideas what it could be?
:conf
Jonault
Re: clunking car
Postby Jonault » Wed Jul 30, 2008 3:24 pm
Could be a CV joint on it's way out. :(
silencer51
Re: clunking car
Postby silencer51 » Thu Jul 31, 2008 11:42 pm
It could be a worn CV joint, loose steering rack bolts, a worn engine mount (usually the gearbox mount on the underside of the car is the first to go) or something in the suspension...
Set dephasers to stall!
jason
Currently Drives:: GT 150
Location: Hardings Renault, Hemel Hempstead 01442 292506
Re: clunking car
Postby jason » Mon Aug 04, 2008 9:20 am
Some times the sub frame bolts on the front need a little tweak .....had a couple in for repair with same prob...... good luck :cool:
Megane II GT 150 "07"
