I'm new to the forum, and kind of wished (!) that i'd found this before purchasing my 2004 1.6VVT Megane... but, ah well! 'tis done now and forearmed is forewarned, or something like that
I'll jump in with my questions.. hopefully this is ok.
Steering Lock - no warning lights or anything, but when the ignition/engine is switched off, the steering doesn't 'lock' (security lock). It tries to, and clicks a bit and even locks but a small amount of effort and it can be moved. Is this normal? Doesn't sound like, thought i'd check.
Steering - drives well in a straight line, but on a progressive bend the steering does fight a bit to straighten up - also occasionally pulls quite hard depending on the camber in the road. Doesn't feel broken as such, but can be quite alarming. Is this a Megane II characteristic? Didn't notice it on other meganes i test drove. No uneven wear.
Starting - occasionally immediately cuts out after startup - starts fine on second attempt. Noisy as a bag of spanners for 2-3 seconds then fine. Do I need to be worried?
Steering height adjustment - handles snapped off. Is this an easy fix? Should I take back to dealer to fix?
Oh, and the STOP light is dimly lit (only noticeable at night). Should I be concerned? Its not fully lit, but is not light leaking from other bulbs either.
Other than that, 32k and some history.. 32mpg around town, 38mpg on a run. Seems basicaly OK.
Thanks!!! Sorry about all the questions.
cheers
Mike
