Rear wheel excessive tyre wear/camber problem
Posted: Tue Jul 22, 2008 11:59 am
Hi All,
I'm driving Renault Megane 1.5dci Sporttourer Dynamique, 07reg. Tyres 205/55 R16 91H both front and rear + alloy wheels as per Renault standard spec. Continental Premium Contact tyres as per Renault standard.
I noticed that the left rear tyre has excessive wear on the outside. On the outside the thread is 1.6mm (legal limit) when on the inside it is about 3.5mm. Both front tyres have 3.5mm tread.
It was fine during the first service (8500miles) equal tyre wear at the rear and front (+-0.5/1.0mm). At second service (16600miles) I can see the difference and the excessive wear at the rear tyre.
I hit a pothole some time ago on the left hand side and that can be the cause (had to change rims they were bent 20mm).
Question: How you can change the camber at the rear? I was told by Kwikfit and National that you can't and they advised to go to the Renault dealer - Park Motors in Motherwell.
Or maybe something is bent but can you adjust rear in any way?
Anyone had similar situation?
Slawek
Slawek
