My 53 1.6 VVT Megane will not start. It turns over without any problems but fails to fire, it has happened once before but then started working again without any interferance from me.
I gather the TDC may be one possible cause, where is this located and how do I clean it.
What else could it be , Reanault want £60 to run a diagnostic on it!
Starting Problems
Starting Problems
Megane II 1.6VVTi 5dr Expression Dec 2003
Re: Starting Problems
The TDC sensor is located at the top of the bell housing next to the engine block. It is held in place by two bolts but is hidden from view by various pipes and cables. When you remove it, clean off any dust and iron filings before refitting. Disconnect and reconnect the electrical connection to remove any oxidisation.
Managed to get my hands on it and move it around a bit, it started soon after. There is no way I will be able to get to it, I am no mechanic!
