Bubbles in fuel line ??????????
Posted: Sat Jul 12, 2008 6:51 pm
by gavinc
bubbles in fuel line how do i bleed it. its before the fuel pump coming from filter hope somone knows.
![banghead :banghead](./images/smilies/icon2_banghead.gif)
Re: Bubbles in fuel line ??????????
Posted: Sat Jul 12, 2008 8:53 pm
by WebCode
Bubbles in the fuel line means that you have an air leak somewhere in the system.. The fuel system on the 1.5 DCI is self bleeding so bubbles is not good..
Posted: Sun Jul 13, 2008 9:21 am
by gavinc
Just hopeing it clears no bubbles now just like a mist now and again passing around the pipes going to pump dodgy fuel i hope but any advice would be great.
![sad :-(](./images/smilies/Joker_PDT_28.gif)
Posted: Sun Jul 13, 2008 10:06 pm
by Ray
i had bubbles in mine after a Renault dealer replaced a glow plug... needless to say the engine kept cutting out and i lost power at 30mph at a roundabout on the way to the dealer to fix this problem!!
Posted: Mon Jul 14, 2008 8:38 am
by cactusbob
Has the 1.5 got the hand priming pump like the 1.9? Giving that a few squeezes, and then running the engine, and then repeating normally gets rid of most air
Posted: Mon Jul 21, 2008 2:50 pm
by gavinc
pumped the fuel bleed there seems to be clouds of white in the pipes (like a mist was last filled at tesco)just hope'ing its bad fuel and it clears but the lights still on will try shell when it runs down..
Posted: Mon Jul 21, 2008 8:58 pm
by AlexB
Drain water from the fuel filter. There is a bleed screw at the bottom of it.
Posted: Thu Jul 24, 2008 7:31 pm
by gavinc
replaced air/fuel/oil filter oil glowplugs egr valve cleaned could not find oxy sensor just wondering what els it could be since the service was done the drive
is great no judders splutters anythink. will i need to get the fault wiped.need advice any one...
