Bubbles in fuel line ??????????
- Currently Drives:: Silver 2004 15 dci
bubbles in fuel line how do i bleed it. its before the fuel pump coming from filter hope somone knows.
silver 15 dci no mods as yet//
- WebCode
- Rally Driver
Re: Bubbles in fuel line ??????????
Bubbles in the fuel line means that you have an air leak somewhere in the system.. The fuel system on the 1.5 DCI is self bleeding so bubbles is not good..
Just hopeing it clears no bubbles now just like a mist now and again passing around the pipes going to pump dodgy fuel i hope but any advice would be great.
- Ray
- Site Admin
i had bubbles in mine after a Renault dealer replaced a glow plug... needless to say the engine kept cutting out and i lost power at 30mph at a roundabout on the way to the dealer to fix this problem!!
Has the 1.5 got the hand priming pump like the 1.9? Giving that a few squeezes, and then running the engine, and then repeating normally gets rid of most air
pumped the fuel bleed there seems to be clouds of white in the pipes (like a mist was last filled at tesco)just hope'ing its bad fuel and it clears but the lights still on will try shell when it runs down..
Drain water from the fuel filter. There is a bleed screw at the bottom of it.
replaced air/fuel/oil filter oil glowplugs egr valve cleaned could not find oxy sensor just wondering what els it could be since the service was done the drive
is great no judders splutters anythink. will i need to get the fault wiped.need advice any one...
Users browsing this forum: No registered users and 88 guests
