Pollen Filter - leaves coming through fans
damiansaint
Currently Drives:: Renault Megane 1.5 DCI Authentique
Postby damiansaint » Tue Jun 17, 2008 9:30 am
I take it this is not supposed to happen. I have only had the car a few days. I was going to look to see if there is a pollen filter in.
How hard is it to get to and where is it located.
Any advice is appreciated.
sav0
Currently Drives:: Megane 1.5dci 53 Plate
Re: Pollen Filter - leaves coming through fans
Postby sav0 » Tue Jun 17, 2008 10:49 am
For the Megane II the pollen filter is down near your clutch pedal remove the cover and you should be able to zigzag the filter out.
damiansaint
Postby damiansaint » Tue Jun 17, 2008 11:08 am
Cheers for that mate, sounds a doddle. Its a 03 reg megane so I am guessing its a megane 2. Will have alook tonight to see if I can rid this problem
damiansaint
Postby damiansaint » Tue Jun 17, 2008 11:41 am
So what differs between Megane I + Megane II
Mine as I said is 03 1.5 DCI authentique is it a I or II, It would be nice to know what the dates are and why they did this
Gav
Postby Gav » Tue Jun 17, 2008 11:44 am
Megane I
Megane II
damiansaint
Postby damiansaint » Tue Jun 17, 2008 11:56 am
I thought thats what it was. Cheers for the pics made it especially easy.
damiansaint
Postby damiansaint » Tue Jun 17, 2008 1:02 pm
Do all megans have a pollen filter?
Mine does not have A/C but I think the pollen filter needs changing as there are leave blowing through the air vents.
Any advice is greatly welcomed
damiansaint
Postby damiansaint » Tue Jun 17, 2008 1:39 pm
also as per the above question. how can I find out the spec of what the 1.5 DCI authentique, I know its the base model but does it have things like alarm etc
Jonault
Postby Jonault » Thu Jun 19, 2008 7:32 pm
The Renault Compact 7887 alarm (Thatcham cat 1) was fitted as standard to the Dynamique and above. It may have been an option on the Authentique and Expression so check your handbooks for any give away paperwork about whether you have one or not.
Bumpy macaroon
Postby Bumpy macaroon » Wed Jun 25, 2008 1:32 pm
damiansaint wrote:Do all megans have a pollen filter?
Both of ours have filters, pre and post facelift, derv and a petrol air con on both,
popped into allfrauds the other day to try and get filter, quoted as special order and cost £20, anyone got contact or details for cheaper.
Bumpy and full of coconuts.
renier
Postby renier » Wed Jun 25, 2008 4:37 pm
sav0 wrote:For the Megane II the pollen filter is down near your clutch pedal remove the cover and you should be able to zigzag the filter out.
Although it is possible to get the old filter out this way (it will crack/break on pre-defnined points), you will have to remove the dashboard cabinet before you can put in the new filter.
damiansaint
Postby damiansaint » Wed Jul 02, 2008 3:18 pm
The crack pre defined points are there for a reason. Bought and fitted the pollen filter the other day and you have to crack it into small pieces to get it in. Once you do this it goes in fine. Its been 3 weeks since its been fitted and the leaves noise blowing tthrough the fans have stopped althogether
The filter was £15 from renaul direct and they had it in stock
renier
Postby renier » Wed Jul 02, 2008 3:21 pm
Have you been able to get it in without removing the dashboard cabinet?
Removing this is the standard procedure when the filter is replaced at my local Renault dealer.
cactusbob
Postby cactusbob » Thu Jul 03, 2008 12:58 pm
It's easy enough if you are patient :)
225 5dr FF + Xenons
http://www.meganesport.net
Postby AlexB » Thu Jul 03, 2008 1:08 pm
Yes, crack it before installation. It is described in the official manual, see p.70 here:
https://meganedoksi.uw.hu/MEGANE_II/MR364MEGANE6.PDF
This manuals are pointed at in my message in Links.
damiansaint wrote:The crack pre defined points are there for a reason. Bought and fitted the pollen filter the other day and you have to crack it into small pieces to get it in. Once you do this it goes in fine. Its been 3 weeks since its been fitted and the leaves noise blowing tthrough the fans have stopped althogether
Users browsing this forum: No registered users and 184 guests
