Radio Problems
louby.loo
Currently Drives:: Megane authentique II
Radio Problems
Postby louby.loo » Mon Jun 09, 2008 8:39 pm
Hi, I would like some help please.
My Megane's radio only stays on for 20 minutes before turning itself off. It used to come on and off with the key but now its only turned on manually.
Problem is I dont have a user manual for it. I am sure it must just be a button I pressed.
Thanks in advance Louby.Loo :D :idea
robznet
Currently Drives:: Megane 1.5dci
Re: Radio Problems
Postby robznet » Mon Jun 09, 2008 8:48 pm
Hi there! - first of all, welcome to the MOC! Do you mean that the radio stays on for 20 mins without the engine running? If so - that's a standard (but very annoying) feature. If it only stays on for 20 mins with the engine running, or with the ignition on, that's a problem I have not seen before. I'm sure someone on here will know more than me though, great bunch of guys (and gals) on here.
Rob
louby.loo
Re: Radio Problems
Postby louby.loo » Mon Jun 09, 2008 8:50 pm
it happens when the engine is running.
thanks for the welcome. :hug
fraser
Re: Radio Problems
Postby fraser » Mon Jun 09, 2008 9:21 pm
Check your fuses. My wife had the exact same poblem with a clio and it was a blown fuse
robznet
Re: Radio Problems
Postby robznet » Tue Jun 10, 2008 12:23 am
OK - as raser says, it is possibly a fuse issue, no ignition controlled feed I would guess. Which would explain the 20 min limit with the engine running. Have a look in the fusebox.
Rob
robznet
Re: Radio Problems
Postby robznet » Tue Jun 10, 2008 12:27 am
OMG - late at night gremlins again! - just caller fraser raser!!!! - sorry mate, that will teach me not to cut and paste when I have been to the pub! :banghead
Rob
robznet
Re: Radio Problems
Postby robznet » Tue Jun 10, 2008 12:29 am
Ok Ok - I knew it was really Fraser - just testing!!! :-(
Rob
tempo*
Currently Drives:: Megane II 1.4 16v
Re: Radio Problems
Postby tempo* » Tue Jun 10, 2008 2:26 pm
I have had same problems.
Replace rear wiper fuse (I know, it doesnt make sense!) but it does work.
Other symptoms will include failing to start/stop radio on entry or exit, and cig lighter not functioning. Halfords do fuses for about £2 and if you have small enough fingers its a doddle!
Users browsing this forum: No registered users and 81 guests
