hi,
when ever i am driving and come to a stop and then i set off gain i have arealy strong smell of egg in my car, the same happens when i reverse, and its not something i could get used to to be honest, does anyone know what it could be and how it can be fixed? thanks
eggy radiator
- WebCode
Re: eggy radiator
It is Sulphur Dioxide you are smelling.. This can be attributed to an number of things.. All of which are related to combustion. ie: Defective catalytic convertor, Lambda sensor, Coil pack, Spark Plug etc..
Have you had issues with misfiring in the past? If so then unburnt fuel will have spilled on to the Cat Monalyth, this fuel ignites in the Cat and quickly destroys it..
- Currently Drives:: renault megane expression mk2 1.4 16v pearl black
Re: eggy radiator
when i start the car it sometimes takes 4-5 attempts for the car not to stall, even if i rev the car for 20-30 seconds it will still stall.
i it expensive to have it fixed?
- IainMW
Re: eggy radiator
magnus1 wrote:when i start the car it sometimes takes 4-5 attempts for the car not to stall, even if i rev the car for 20-30 seconds it will still stall.
Is it a 1.6vvt by any chance?
Failed Dephaser Pulley possibly? Webcode, any further things to consider?
- Terabyt3
- Currently Drives:: 04 1.4 16v Megane 3dr
Re: eggy radiator
the eggy smell definatly suggests a Cat problem. thats where id be pointing my shaking finger.... i nearly bought a focus (don't hate me) from a friend until i got in it and smelt eggs. He thought it was his pollen filter and i had to break the news to him it was more likely his Cat. 2 days later he came back and called me alsorts of b******s for finding such an expensive fault lol. He traded it in though and jumped on the astra bandwagon and now looks like veryone else
'04 1.4 16v 3dr Extreme
Re: eggy radiator
na its a 1.4 16v.
by the last post i take it catalytic converters are expensiv to replace?
should be fun, got my MOT next month!
cheers for the help.
- Terabyt3
Re: eggy radiator
it depends really i had my cat exaust and downpipe go in my corsa and it was £220 for the lot which was cheap. My mate looked into gettin just his cat done on his focus and it was£300
- IainMW
Re: eggy radiator
magnus1 wrote:na its a 1.4 16v.
Check out everything Webcode mentioned but also search the forum for Throttle Body problems
Re: eggy radiator
Rich mixture plus supermarket fuel. Switch to Shell and check the sensors, lambda sensor first.
The smell of rotten eggs, BTW, is not SO2, but hydrogen sulphide H2S, which does not change much in terms of diagnosis.
Users browsing this forum: Google [Bot] and 94 guests
