Please can somebody tell me where the throttle body is located on a 1.4 as i need to give it a clean or if somebody has a piccy of it that would be great.
Throttle Body Location
Re: Throttle Body Location
Cleaning is described in Technical Note 3799A, and I have not seen it in English. All these documents are a part of DIALOGYS program, which is not freeley available, but can be found on ebay or bittorent and alike. A quick web search returned a link in a wrong language, but the pictures may help:
https://dreamer222.narod.ru/NT/3799A.pdf
I also saw it in French, but the link is gone. So, keep searching.
3504A is also relevant
The procedure in simple: read the manual (below), disconnect the battery, remove throttle body, spray inside with carb cleaner, wipe with a special tissue, blow with compressed air, put it back, connect the battery, reset possible error codes, upon power-up (start, stop, start and wait) the throttle must perform self-calibration -- check result with Clip. This is in theory. In practice you just remove it, clean and put it back. Try cycling power -- it may force recalibration. Make sure that no fibres are left inside and read the manual for torque values etc. Keep carb cleaner away from plastics and electrics -- it dissolves some plastics.
Engines are described here:
https://meganedoksi.uw.hu/MEGANE_II/MR364MEGANE1.PDF
This is where my help ends, as my engine is a diesel.
- Currently Drives:: Megane 1.4 + C180K
I was in Halford's last week and curiosity got the better of me. Found the Haynes manual for the Megane and looked up "Throttle Body, removal." The first sentence read:
"Depressurise the fuel system as previously described."
I put the book down and backed away slowly.
I saw the depressurize comment in the manual too, i dont think its necessary though as far as im aware, dont quote me on that though!
Why are you reading a non-Renault document? There is nothing about depressurising here:
See section 12A.
See section 12A.
- Currently Drives:: 04 plate 1.416v authentique pearl black
or one hours labour at a garage you trust!!!!
1.416v 04 authentique pearl black
AlexB wrote:Why are you reading a non-Renault document? There is nothing about depressurising here:
See section 12A.
For the same reason I don't take my Megane to a Renault Dealer. And the Haynes pictures are nicer.
- Currently Drives:: renault megane ii 1.5 dci 80bhp 2005
About the MR364MEGANE1.PDF, PLEASE HELP, i CAN'T FIND IT ANYWHERE, THE ENGLISH VERSION OFCOURSE
MANY THANKS
MANY THANKS
