Air filter change
xcz_megane
Air filter change
Postby xcz_megane » Thu May 15, 2008 11:55 am
Just changed the air filter on my megane, however there is now a slight low rumbling noise when you accelerate through 3rd gear and up. I can only really compare the sound to the sort you get off the exhaust of modified cars with mufflers (i think thats what they are). Any info/tips? thanks
IainMW
Re: Air filter change
Postby IainMW » Thu May 15, 2008 4:27 pm
Have you got everything back together correctly?
Sounds like you might need to check the filter is fitted correctly and that the air box is sealed and secure?
xcz_megane
Postby xcz_megane » Thu May 15, 2008 4:56 pm
Spot on IainMW, shoddy workmanship on my part, I hadnt put the compartment back in tightly enough and air was escaping. I took the whole thing apart and did it again and its running great! thanks!
nickbell69
Currently Drives:: megane 1.9dci priv 53
Postby nickbell69 » Fri May 16, 2008 7:23 pm
xcz_megane wrote:Spot on IainMW, shoddy workmanship on my part, I hadnt put the compartment back in tightly enough and air was escaping. I took the whole thing apart and did it again and its running great! thanks!
I see a great future working as a renault technician for you xcz. £150 for changing the air filter then £80 for diagnostic when the car came back in, plus a 2nd repair bill for a fault totally unrelated to the air filter, give them a ring i'll give you a reference :lol:
xcz_megane
Postby xcz_megane » Mon May 19, 2008 10:35 pm
LOL I reckon that could be the key to my fortune! One job leads to another!!
Users browsing this forum: No registered users and 70 guests
