Panoramic Roof
louiserd
Panoramic Roof
Postby louiserd » Fri May 02, 2008 12:37 pm
Hi everybody,
My roof has been fine up until now and today it won't open, the back of the front piece of glass taps against the back piece of glass and for safety it closes, it works perfectly if I put my hand at the back just to help it up a little.
Is there a simple fix for it?
robznet
Currently Drives:: Megane 1.5dci
Re: Panoramic Roof
Postby robznet » Fri May 02, 2008 8:44 pm
I would guess that maybe the rear slider has broken because as soon as you try to open the roof - it should rise first, ie: before it starts to slide backwards. I'm only guessing on this but you could get a friend to try lifting the rear of the roof as you operate the control knob. Worth a try and you will know in which direction to look.
Rob
robznet
Re: Panoramic Roof
Postby robznet » Fri May 02, 2008 8:47 pm
Sorry - didn't read your post correctly, you have already tried my suggestion! In that case I would give the rear sliders a squirt of WD40 or similar, they might be stiff after the winter period.
Will try to read posts properly in future! :-(
Rob
louiserd
Re: Panoramic Roof
Postby louiserd » Fri May 02, 2008 9:06 pm
Plenty of silicone lubricant on it throughout my ownership and it slides well unless I have mixed the rear slider position?
Thanks for your reply.
