Gday
I have a couple of issues wuth my 05 megane. Hope someone can help we with a solution.
List of problems (which I beleive to all be related:
- Cig lighter not working = no tom tom, or Ipod
- Air con and heated rear windscreen not functioning
- Radio/CD doesnt turn off when engine stops/door is opened
- Radio/CD doesnt start up when entering (as it used to do)
- Radio/CD times out (and switches itself off) every 20 mins when driving
I have looked at the fuses and tried to insert new ones, particulaly into the gap where the cig lighter fuse should go - however its a if there isnt meant to be one there at all - it wont hold a new one in place.
Any suggestions would be great - this is driving me nuts!
Electrical issues - fuses?
Re: Electrical issues - fuses?
All those are based on one fuse so it should be your problem (have you got any cause of short circuit in your 12v socket or used a faulty plug before?). The fuse map isn't very clear, check them all
Thanks - as i suspected.
I have noticed that the metal housing of the 12v socket is loose - so might need to check this out. Superglue ?????????????
Can anyone tell me which fuse I should be looking at - is it the 15amp one on the left hand row?
Could they make the fuse box any harder to get at!!
Shouldn't be that, it can be loose, it has a plug in underneath (can lift the gaiter by just lifting carefully the plastic ring and reaching underneath). It's usually a rubbishy 12v plug that causes it. Without going to look I can't tell you but if you use the tweezers you can pull out each one and check which i blown, 15a sounds right.
I had the very same problem 4 weeks ago.I blew the cigar lighter when an adaptor fell apart & i used a pair of tweezers to remove the fuse & plastic parts .Then lost cigar,climate & all associated buttons on dash & strangly f and r washers (but not wipers !?!).+radio worked back to front. problem......the rear wiper fuse altho the wipers still worked.
Hope this helps you, regards, martin.
EX WINDSCREEN REPAIR SPECIALIST.
'04 MEGANE SPORT TOURER 120 DCI PRIVILAGE,PLATINUM .LIMO TINT +'P BOX' TUNING>145+BHP,350 N.M.TORQUE. ITG FILTER .TOM TOM 510 SAT NAV. HOPE I'VE GOT A PEACH,NOT A LEMON! IT'S NOW OUT OF WARRANTY.. SOLD!
that is helpful, ill give it a go tonight and report back. I too have lost the wiper jets, but the wipers are fine.....
Users browsing this forum: Google [Bot] and 78 guests
