Do i need coolant
ian_kell
Do i need coolant
Postby ian_kell » Mon Apr 21, 2008 8:28 pm
56 plate 1.6 Petrol with 24,000 on clock
Lookign at engine today and its close to mininium
Does it need filling and if so what is the correct stuff to buy?
Iain :D
IainMW
Re: Do i need coolant
Postby IainMW » Tue Apr 22, 2008 7:18 am
Probably best to check what it's like when cold and when hot?
By the sound of things I'd say you could do with a drop of the stuff though!
Go to your local dealer and get some from there, you cannot mix coolants so is important you get the right one for your car :cool:
Postby AlexB » Tue Apr 22, 2008 8:43 am
Yep, some coolants may produce gel or solid residue if mixed. It is safer to get coolant from the dealer. I am sure that topping up ONCE with SMALL AMOUNT (1l or so) of DISTILLED water will not harm the system.
In any case, check the level and cleanliness of the coolant properly (the manual may help) as its loss may indicate a bad fault. Too much coolant is also bad as it expands when the engine is hot.
WebCode
Postby WebCode » Tue Apr 22, 2008 5:39 pm
The level should be between Min/Max when cold.. The coolant lasts for 4 years before replacement is required..
It will not harm the strength if you need to "top up" the bottle with a few 100ml's of tap water.. Distilled water is not necessary, Tap water is fine..
ian_kell
Postby ian_kell » Tue Apr 22, 2008 6:02 pm
So just add tap water? It is just above min when cold (checked after 3 hours not running!)
Cheers guys
Users browsing this forum: No registered users and 83 guests
