Hi I own a 53 plate 1.6 vvt with 25 000 miles.
While driving the other night the speedo started to read low and then the ABS Warning and Service Lights came on.
Brakes seem OK.
Any ideas and can you reset these warning lights,
ABS Warning Light
Re: ABS Warning Light
Check your brake fluid level first, then check to see that your brake pads aren't worn out. If it's neither of those problems then you could be looking at electrical faults.
Users browsing this forum: Bing [Bot] and 81 guests
