parcel shelf
parcel shelf
Everytime i close my boot, my parcel shelf always seems to fall down and never fits snug like it should do, so i then have to lean over from inside the car to lift it back up. Does any1 else have the same problem?
Silver Facelift 2006 3 door 1.6vvt Megane Dyanmique
Re: parcel shelf
Is it located properly in the lugs?
Was: '52 Megane 1.9dci dynamique with everything standard plus: electrically folding mirrors, handsfree locking, climate control, heated seats, panoramic glass roof, in-dash CD changer, TunePoint iPod, etc. etc.
Now: '55 Laguna Initiale
Re: parcel shelf
ye, i put in properly befor i close the boot, yet it still slides down.
- Bumpy macaroon
Re: parcel shelf
i take it when you close the boot it pops of the lugs,
have a look at the shelf and rear of seats, may find it is catching,
wifes was doing it one side (passenger side) I grabbed a torx bit and undid the two bolts holding the plastic bit that has the lug and removed it, on the passenger side it also has the boot light be careful when pulling it out (needs a little pull), you will see once its off a locating spigot close to the screw nearest rear seats, also note the plastic slots that the two screws go into, as they are slotted you have a bit of room to play with i refitted the panel but fitted it further away from the rear seats, it has stopped it popping off, but i will be adjusting it a bit as the shelf is now a little to far back guess its a bit of trail and error
Bumpy and full of coconuts.
Re: parcel shelf
Thanks for that, ill give it a try
- Currently Drives:: 57 Reg Megane Hatch DCi 106 Dynamique + Comfort Pack : Extreme Blue
Re: parcel shelf
Hi, guys!
1) When you say the parcel shelf is located on the lugs - have you given the shelf a good push, so it Clicks, and is not just resting on the lugs?? (Yes, I know you have - sorry, sorry, just thought I'd ask the blindingly obvious!!)
2) If you work thru the Tech Spec of any Meg Hatch model on the Renault website, it proudly says: '2 position rear parcel shelf'. Where the heck is the 2nd position?? In the garage???? Neither of mine have had a 2nd position that I've ever found - unless it's on & off the lugs!!! (see above). Anyone any idea?? [PS - it also says in the handbook: "on no account put anything on the rear parcel shelf"!! Wonder how it came to be named 'parcel shelf', then? And what are those thoughtful depressions for??]
ATB Redshoes
ATB Redshoes
Redshoes
- Bumpy macaroon
Re: parcel shelf
two positions? all i can think of is
position 1 flat when boot closed,
postion 2 angled up when boot opened,
of course you have some more options,
position 1 with boot open undo the string clips
and of course the out of the car propped up against the garage wall position
oh forgot the dam thing come off its lugs and fallen into the boot position
Re: parcel shelf
Thanks, B Macaroon!
I never thought of 1) Flat 2) Angled up when boot is open, but I'm sure you're right,!!
And all thanks to 2 technologically advanced pieces of Renault string
Regards
Regards
- Currently Drives:: Renault Megane 1.9 DCi
Re: parcel shelf
Redshoes wrote:And all thanks to 2 technologically advanced pieces of Renault string
And for that privaledge they will charge you £20 per string at the stealership haha
Renault Megane II - 1.9 dCI
- nickbell69
Re: parcel shelf
Mattj wrote:Redshoes wrote:And all thanks to 2 technologically advanced pieces of Renault string
So optimistic mattj £20per string but there is labour for fitting it which the stealership will not have mentioned and vat on top.
Re: parcel shelf
yeh turning a simple job in to one costing hundreds !!
got charged £202 the other day for diasgnosics and a report to the warranty company !!
Users browsing this forum: Google [Bot] and 34 guests
