Still having problems!!! 04 1.416v
Posted: Thu Mar 27, 2008 9:02 am
hi guys
Im Back to the drawing board- after reading and posting on the forum and doing some research with regards to hot starting and acceleration probs i had the TDC sensor changed..(for one that renault has upgraded) and changed the coolant sensor, and also had 2 weeks before the entire engine management settings reset as on the diagnostic every single light lit up- which was put down to the car having had a flat battery at some point in its life.- this all seemed to work, the car accelerated and sounded like it should, and even started when hot- FOR TWO DAYS!!!!..then lo and behold we are back to not running well.- what i have to assume is it must be something to do with the ECU or a sensor for it to work well after being reset, but then revert back to the way it ran before. the car just seems hesistant, especially if you accelerate in a higher gear from a lower speed..say from 30 MPH in 3rd...and bizarrely in a complete change to when i first got it, has been running better when cold- does anyone have any ideas- ive seen posts for having the injection computer reprogrammed, cleaning the throttle body, and checking the air intake pipe- but some of these seemed to apply to a 1.6vvt- no warning lights come on at any point.- could a long fast blast on the motorway sort it?- renault tell me the ECU adapts to driving style and i have only done short journeys recently.
it is an 04 1.4 16v, FSH and 33000m
Any ideas would be welcome.
