Indicator and brake light problems.
When i press the brake pedal and indicate the indicator flashes fast and alternates between the brake light and indicator.any ideas what the problem could be.
- Currently Drives:: Renault Megane 1.5 dCI, 06
Re: Indicator and brake light problems.
Hi All,
Frequent visitor to the site, but unfortunately this time I need some advice.
I am now experience a similar problem as to what is identified by the original poster.
I was aware that my indicator was flickering faster when the brake pedal is pressed, however this morning I was alerted by a colleague to the fact that my brake lights are also flickering/flashing.
I am wondering what could cause the issue, where to check (i.e. in this thread is mentioned Multi Plug - where is it?) I am a complete idiot when it comes to cars but once I locate what I'm looking for not to bad at fiddling with it.
Vehicle is obviously a Megane II, 2006 1.5 dCI
Located behind the rear cluster. From memory there are two sort of 3 pronged screws to remove. The entire cluster comes off such that you can get access to the bulbs. Other than that, prise off trim/carpet near to those locations and you will be able to see the wiring.
- Currently Drives:: Megane ii dynamique 1.4 16V. Bought new in 2003
davelowe wrote:Located behind the rear cluster. From memory there are two sort of 3 pronged screws to remove. The entire cluster comes off such that you can get access to the bulbs. Other than that, prise off trim/carpet near to those locations and you will be able to see the wiring.
Hi folks, this is my first post, so please bear with me. I bought my Megane new in 2003 and now its done 45K miles. The rear light clusters are partly corroded and causing the problems outlined in this thread. I cleaned them by light filing and gave them some WD40. This was a temp fix. My Question is:- Are new clusters available online and if so can someone guide me to the correct site.
Many thanks from Cork, Ireland!!!!
Hi
I know this is an old post but I am having the same issue.
I have changed all the bulbs on both sides and checked the multiplugs and all ok. I have found the earth and sanded down to bare metal and still the same problem.
Any other ideas?
Any other ideas?
Users browsing this forum: Majestic-12 [Bot] and 78 guests
