hi guys
my latest problem is as such.
when i turn my blower dial to 1 or push the AC button, i can hear what sounds like a motor clicking on, then a humming noise until i turn the AC or blower off.
to me it sounds like whatever it is that takes the air in is really struggling. any help would be great.
kyle
air con problem
- kylehimself
- BurntCarcus
- kylehimself
i have a very similar problem and as such thought it was the gas that needed redoing however when rac man came out to me after i had ignition coil failure (grrrrrrrr) he instantly identified a bearing was starting to fail in the air con compressor so i suggest before u part with the 50 odd quid for a regas u get an expert t pop his head under the bonnet
- kylehimself
- BurntCarcus
When you get your aircon regassed they also put oil in it to stop such problems with the bearing, my guess is you have ran out of oil and its knackered the bearing, you might get away with getting it filled with oil, if not its new bearing time which from what i hear can be costly to fix, kyle get yourself over to kwikfit on the newtonards road near the fire station and get it regassed, think its about 45 quid. They will give you a print out of how much oil/gas they take out and how much they put back in. More oil in it may stop it, unless its done to much damage. I went to kwikfit and they got 2ml of oil out, thats when the guy explained it all to me, said i was lucky i came in when i did. Ill be going back there every 2 years from now on. Hope you get it sorted with the least cost.
Users browsing this forum: Google [Bot] and 68 guests
