Hi got a new problem with my megane the service light came on and the computor reads check injection any one help.
cheers davy
check injection light
re problem
Is this an intermittent fault or have the lights stopped on?
You could have a faulty injector, or it could be the erg valve need cleaning.
All this has been covered in other topics so you should find you answer in here somewhere.
regards
Steve
regards
Steve
if the warning light goes off after a re-start - warm engine for 10 mins, the it will be a glow plug gone. the can be purchased from GSF for about £10 each. changing them is fairly easy. if the light stays on even with the engine warm and after a re-start, then it unlikely to be glow plugs.
good luck
good luck
- nickbell69
- Currently Drives:: MEGANE 1.9 DCI
Re: check injection light
i have a 1.9 megane dci and have the fault check injection displayed and service light power seems fine and the display doesn't go off like other i've seen so probably not glow plug or turbo/injector problem but only getting 37mpg average which seems low for a diesel which made me think was it the lambda or oxygen sensor i believe the grv could also be the problem but need more can you help-dave
Users browsing this forum: Google [Bot] and 41 guests
