Newbie here with a few 1.4 questions
Hello all i have just bought a 1.4 dynamique in met black and must admit i quite like the car. I had a mazda3 sport but had to sell it to buy 2 cars a corsa for the missus and the megane for me. My question is that when i back off the gas i get a very slight rattle / wobble noise from the engine but this only happens between 3000 and 3600 revs when driving but if the car is idling and i rev it the noise is gone the timing belt and water pump has been done. Is this just that it is a different car with different noises has anybody else with a 1.4 got a similar noise. Thanks in advance for any replys. Alan
- kylehimself
I have a tappet rattle that you can hear when decelerating between 3,100 and 3,000rpm. You can also hear it when you change gear. I mentioned this at the first service and I was fobbed off with "It was the exhaust heat shield but we've bent it back". I mentioned it a couple of months later and took a Renault Technician out for a spin. He acknowledged that there was a noise but they weren't prepared to do anything about it until it affected the performance/mpg of the engine. I mentioned it again on the second annual service and I was fobbed off with "It's a noise from the manifold". Someone asked me if it was a diesel when they heard it idling as the rattle is that bad. I only have until December before the warranty runs out but I expect they'll be dead keen to look into it once the warranty has expired.
Thanks for the replys i suppose it could be more of a whine noise the noise hasnt got any worse but as some one mentioned it is only when taking your foot off the gas between 3000 / 3400 that you get the noise. You can here the teppets a little bit on start up but that is only with the window open and a cold morning but the car has covered nearly 70k so that is probably understandable. Thanks for the help
Users browsing this forum: No registered users and 74 guests
