drivers window problem
how do you re set the drivers window, mine is stuck in up position. i have read about regulators on here but is there anything else i should check. thanks in advance
- nickbell69
same prob
Done the fekn reset thingy
But no use
Back drivers window stuck doon
took inner panel aff
and cable looks tight at botom and slack at top
When trying to put window up - or down via switch
Can hear the motor trying to move - but nowt happens
PS - wheres the regulator located in the car - and any one got a link to e bay where you can buy a regulator ?
OOps its a 2004 1.5 diesel 5 door megane
TIA
But no use
TIA
[ÐÃÑ]™
- Old Bikers never die - they just get Faster -
Re: drivers window problem
how did you get the dorr panel off, right rear!
Users browsing this forum: No registered users and 67 guests
