Check Injectors light @ 130mph
- BurntCarcus
- Currently Drives:: Grand Scenic 2008 1.9Dci (130)
Hi guys, had the check injectors light come up on my dash when i got to 130mph (private road of course). Car had very little power, so pulled over and switched it back on again. Light is now off and power is back to normal. Anything that i should check or was i maybe not getting enough derv or air?
Back from Zafira hell....... Good to be home. Number 3 scenic bought and "im lovin it"
I had the same loss of power thing last night after pulling off the motorway having done a long run. Turbo started whining and next thing I know there's the tell-tale smoke pouring out the back.
Pulled over, tried to stop the engine on the button as the revs went through the roof but wouldn't so had to stall the engine to turn it off.
RAC man said it was a good job I had stalled it or the engine would have gone pop - conrods flying all over the show.
Apparently all due to a known fault with the EGR valve sticking closed so you might want to get that checked out before you blow the turbo like I did!!
pw981 and Ray,
Is there any evidence that this may work? I understand pw981's concern, but these engines are equipped with butterfly throttle valves that reduce stopping time. Under runaway conditions this valve is potentially capable of stopping the engine. A big question, however, is whether the ECU will command it to do so or not...
We already know, that if the button is pressed once, the engine would not stop. Why? The ECU does not do it for some reason. Possibly, it is a safety feature that prevents a driver from stopping the engine while driving. However if the button is pressed 5 times the engine will stop even when driving in gear! So, I can accept that Ray's solution may work.
- BurntCarcus
If i press my start button twice quickly while driving it cuts the power, then the engine cuts when i stop. Tried this myself as i was curious what would happen if, say, your a taxi driver and you get some drunk ejit that presses it. But back on topic, the car is running fine now for a few days so im going to asume its one of the following
1) Not enough air
2) Not enough Fuel
3) Exuast not able to cope.
Basicaly im gonna have to do other things to it to get an improvement at that speed. More than likely ill just back off way before then in the future
1) Not enough air
2) Not enough Fuel
- pw981
AlexB wrote:pw981 and Ray,
Good point you make there alexB, I can see now how Ray's solution may work, hopefully the 3 of us, or any other person will not have to try it!!
2004 Megane II 1.9dCi
- IainMW
BurntCarcus:
Have you considered that it may have something to do with your re-map?
The 2 times that I have actually hit that speed (in my previous Laguna) 1.9dCi 120, I never had any problems.
The new one is just about ready to fly at 100mph, never ventured past that yet.
- kylehimself
Re: Check Injectors light @ 130mph
BurntCarcus wrote:Hi guys, had the check injectors light come up on my dash when i got to 130mph (private road of course).
bein' in northern ireland myself and only 20 odd mins from you. id like to know the where abouts of such roads on which i can speed ...... that is unless said road doesn't exist Mr. BurntCarcus
kyle
- BurntCarcus
kylehimself wrote:BurntCarcus wrote:Hi guys, had the check injectors light come up on my dash when i got to 130mph (private road of course).
kyle
Its classified, and if i tell you i'd have to kill you afterwards lol Its called coveryourback Road
- BurntCarcus
IainMW wrote:BurntCarcus:
Yeah i think thats what it is, the car still had another few hundred revs to go, but its not getting enough derv etc Im sure if i put a new exuast, k&n air filter etc on it would let me rev it right out. Was your laguna still pulling at 130? or was that about its limit?
- kylehimself
BurntCarcus wrote:Its classified, and if i tell you i'd have to kill you afterwards lol Its called coveryourback Road
i thought as much...
kyle
Users browsing this forum: Google [Bot] and 64 guests
