Clutch just changed, now won't engage gear in a morning...
DciDynamique
Postby DciDynamique » Sun Dec 16, 2007 5:50 pm
Just bought a Megane 1.9 DCi and have had problems with the clutch. Just had it changed, and now before you can engage gear the clutch pedal needs to be 'pumped' beforehand. It is fine after this has been done, but once stood, this needs to be done again.
I understand there is no bleed nipple with the car, and it self bleeds - but it doesn't appear to be doing a good job!! Any ideas?
Many thanks
Sean
Postby AlexB » Sun Dec 16, 2007 9:24 pm
I am not sure what advice you are asking for? Is it how to request the garage to do their job properly?
The bleeding procedure is described in the documents pointed at in my message in Links section, page 37A-22 onwards.
Use last link to the workshop manuals!
DciDynamique
Postby DciDynamique » Mon Dec 17, 2007 8:10 am
Hi Alex, I guess I wanted to know if it was normal and if it would settle down after a bit of driving, or if it actually needed to be returned to the garage - which it sounds like it does!!
I don't mean to sound daft but where is the my message links section?? (sorry - bit bad with message boards).
Many thanks for your reply.
Sean
DciDynamique
Postby DciDynamique » Mon Dec 17, 2007 8:34 am
Have found it! Off to buy a Haynes this morning!
IainMW
Postby IainMW » Mon Dec 17, 2007 10:32 am
There will probably be high points on the clutch plate. My Laguna 1.9dCi had it's clutch replaced at only 21000 miles, the first one fitted did exactly the same thing as yours, but this was picked up by the dealer before the car was handed back to me.
DciDynamique
Postby DciDynamique » Mon Dec 17, 2007 10:47 am
Well the symptoms only take place once the vehicle has been stood (e.g. left overnight). After you've initially pumped the clutch a few times before you set off it's fine, and if the car is used consistently throughout the day then it remains fine, but then if it is left for say over a 4 hour period, it starts to need pumping again before the vehicle will first engage gears - this sounds more to me like it is getting air in the system rather than high points in the clutch???
Sean
DciDynamique
Postby DciDynamique » Mon Dec 17, 2007 12:44 pm
Just bought the haynes, not sure where this is "page 37A-22" but on 6-4 of the Haynes it explains about the bleed nipple. I was told by the garage that my vehicle doesn't have a bleed nipple and it is a self bleeding system.
Does anyone know if this is true?
cactusbob
Postby cactusbob » Mon Dec 17, 2007 1:25 pm
The page 37A-22 is in a Renault Workshop manual not a Haynes manual. Take the car back to the garage, you shouldn't have to pump the clutch at all before you can get it to work. Something is obviously wrong
225 5dr FF + Xenons
http://www.meganesport.net
DciDynamique
Postby DciDynamique » Mon Dec 17, 2007 2:32 pm
It's going back in tomorrow. IMHO the clutch seems to have air in it, and needs bleeding. Grrr.
Postby AlexB » Mon Dec 17, 2007 6:06 pm
DciDynamique,
Welcome to the Forum from all of us. Please stay around and let us know of the outcome.
Users browsing this forum: Google [Bot] and 75 guests
