front sus ball joints
How do I change a worn ball joint?
- IainMW
With a worn ball joint changer!
Seriously: It's not to difficult and you should not need any specific tools(other than a ball joint splitter)
But you will need access to a ramp to do it properly, oh' and a set of laser alignment gauges to correctly align your steering geometry once you've changed it, but any decent garage/tyre centre should be able to do that small a small fee.
Have you tackled anything like this before?
Welcome to the club BTW
i think it`s really false economy to change a ball joint,bearing in mind that to make the job easier you would (well i would anyway)probably take the arm off the car anyway,then put a new joint on an arm of which the bushes have done the same mileage as the worn joint! much better to put a full arm on so you`re renewing the bushes as well. only my opinion||
ball joint
IanMw - have rebuilt cars from wrecks - used to be a mech, time served on Rover/Triumph/Land Rover/Jag/Daimler. Not really touched cars for best part of 30yrs and not many old mates left in the trade. None at Arnolds. Currently a factory fitter so not exactly rusty on the tools.
when you say no tools are required you must need a puller/pusher to press ball joint out & back into the lower sus arm?
A quick look sugests removing/replacing sus arm aint a straight forward job.
Just did`nt want to rush into things and be left with car stranded in drive.
John,
Removing the lower arm seems to be reasonably straightforward. The sequence and the torques are in the above link. Check you forum mail for a more precise pointer.
I don't know how to remove/install the ball joint on the arm, as it looks different from the other cars I dealt with. Ask Andy Stephen at Parkers forum, he might know. He changed bushes on his Laguna a couple of times.
ball joints
Unfortunately I don`t speak/read French, being Scottish some would/do say I can`t speak English!!
Ball joints can be bought from alternative/trade suppliers
Tool will probably be similar to void bush rem/rep tool
ball joints
Users browsing this forum: No registered users and 93 guests
