Dull Drone from rear of car, louder at speed
jlscott
Postby jlscott » Wed Nov 14, 2007 6:05 pm
Since picking up our used Megane 3 door 1.5dci (100bhp) we've noticed a dull drone coming from the rear of the car at speeds of around 40mph or more. Around 60-70 it gets loudest. It doesn't appear linked to the engine as it remains when the clutch is depressed or I lift of the accelerator.
We had a local garage check things out and the wheel bearings and so forth were ok. I'm planning on taking it back to the garage where it was bought to have them check whilst its still under warranty.
Has anyone experienced anything similar?
nickbell69
Currently Drives:: megane 1.9dci priv 53
Postby nickbell69 » Wed Nov 14, 2007 6:33 pm
I have a similar drone in the back of mine. Stopped as soon as the mother in law got out!!!!!
jlscott
Postby jlscott » Wed Nov 14, 2007 7:31 pm
:lol:
Thanks, that brought a cheer to the evening.
1963
Postby 1963 » Fri Nov 16, 2007 7:50 pm
Hi jlscott,
sounds like wheel bearing, just had mine done cost about £70. However there are different types of bearings. Some require you to replace the whole disc set as well!!, sorry not greatly technical. Getting that done the part should cost around £80 then there is fitting.
I use Fifeauto Centre in Glenrothes and have always used these guys and they are ver good and trust worthy and don't bullsh1t you.
I'll say ......
Users browsing this forum: Bing [Bot] and 72 guests
