Car pulling slightly to one side
zammov
Postby zammov » Fri Nov 09, 2007 5:03 pm
I have a magane saloon 1.6 petrol. I've been driving it for about 18 months now. I am noticing that the car is pulling slightly to the driver's side. Don't know whether it has been always like this or it developed now. I took it for wheel alignment but everything seems to be ok.
Any suggestions????
R55VYS
Postby R55VYS » Fri Nov 09, 2007 5:20 pm
well if its had the tracking done and all the wheels are balanced it might be down to something a bit more serious, bent rim, steering rack bent, if it had been involved in a bump, etc.
Not to clued up on the situation tho, someone with a bit more knowledge might be able to help you out.
Jonault
Postby Jonault » Fri Nov 09, 2007 5:34 pm
The brakes might be binding a little, feel how warm the wheel is next time you've been for a drive and compare it with the temperature of the other wheel. I assume both front tyres are the same make so it probably won't be down to rolling resistance. If your tyre pressures are OK then maybe a strut bush has worn.
onlydiesels
Postby onlydiesels » Fri Nov 09, 2007 11:35 pm
check the tyre pressures first (although if tracking been done,they should have checked pressures,but you never know!!),+ swap wheels from side to side to see if the problem moves with the wheels.
all this is assuming you don`t have pressure sensors fitted!
Hany Saad
Postby Hany Saad » Sat Nov 10, 2007 8:47 am
I had the exact same problem and it turned out to be wheel balancing.
I had also very little vibrations almost unnoticed when exceeding 90 Km/hr.After I did wheel balancing at a specialist all this was gone forever.
By the way they could not help at Renault.
Megane II 2006 sedan,Grey eclipse (B66),1600cc,16V, VVT,steptronic
