cv joints
nickbell69
Currently Drives:: megane 1.9dci priv 53
cv joints
Postby nickbell69 » Mon Nov 05, 2007 7:15 pm
I have knocking sound when turning out of junctions. Reading other posts it sounds like it could be the cv joints. Does anyone have any info on how i can tell for certain if it is these and also how easy would it be for me to replace them?
markren2004
Postby markren2004 » Mon Nov 05, 2007 7:55 pm
unlikey to be CV joint (but i stand to be corrected).
more likely to be a suspension bush,wishbone or anti-roll bar bush.
The car needs to be visually inspected on ramps to check for any movement with the suspension parts.
is it every time, both left & right turns, worse on full lock ?
nickbell69
Postby nickbell69 » Mon Nov 05, 2007 9:39 pm
both left and right turns. worse at around half lock. Haven't really tried on full lock. Will take it to a car park and give it a go. Car has done 57k so might put it in for 60k service early and see what they say. Don't mind giving it a go myself but obviously need to know i'm changing correct part!!
Ray
Postby Ray » Tue Nov 06, 2007 12:06 am
i have the same with left turns... about ½ to ¾ lock.
nickbell69
Postby nickbell69 » Tue Nov 06, 2007 7:29 pm
Its going in on thursday will let you know what they say.
chrislloydie
Postby chrislloydie » Wed Nov 07, 2007 12:56 pm
My car had its MOT last week and i was advised that there is a knocking noise from the front left wheel when on full lock either left turn or right. I was shown the noise and told that although it wasnt an mot failure, i should get it looked at. Was told it was probably the strut mount.
I am a complete novice with cars, any idea what it could be and how expensive to get it sorted?
1.6 Dynamique 5 dr, tip, Antique Green, 17" 16 spoke alloys, spoiler, DVD, Lexus rear lights, green cotton filter, ipod, TS-Q131C Speakers, limo tints
markren2004
Postby markren2004 » Wed Nov 07, 2007 1:14 pm
is it a "twang" noise when you turn the wheel back and forth? - if so it is the top mount.
struts take about 1.5 hrs per side to remove and replace.
plus parts. so depending on where you take it i would think your looking at £100-£200 for each strut.
nickbell69
Postby nickbell69 » Thu Nov 08, 2007 8:07 pm
Well car has had service with no problems. Nothing found at fault on the steering or front suspension.
Users browsing this forum: No registered users and 72 guests
