tdc sensor
petesafc
tdc sensor
Postby petesafc » Sat Oct 13, 2007 1:48 pm
I have removed and cleaned the tdc sensor, I have service and toxic fumes warning lights on,assuming cleaning the sensor has sorted the problem would these warning lights automatically reset or would this have to be done by dealer? Any help appreciated.
markren2004
Postby markren2004 » Mon Oct 15, 2007 7:46 am
it should reset itself, although i don't know about the facelift model (if yours is one of those). model & age would be useful.
The "toxic fumes" message can also be caused by failing coils, that might be your problem rather than TDC sensor ?
petesafc
Postby petesafc » Mon Oct 15, 2007 7:44 pm
Thanks for the advice there is plenty of sound information here! Mine is a 54 plate(out of warranty 3 weeks ago) 1.6. Have already had 2 ignition coils in last 6 months and this weekend engine kept stalling when clutch depressed and made drivin home from work today a nitemare! The AA man did his diagnostic and said the camshaft sensor had flagged up.I went to dealer on way home bought one of these for £38 fitted it which was easy apart from bolt being flippin hot! so now its fingers and everything else crossed!!
CanadianMike
Postby CanadianMike » Fri Oct 19, 2007 9:53 pm
i have the starting problem , and im going to be looking into cleaning the TDC sensor, but as has been said below, could it be the camshaft sensor?? ive herd 2 different solutions to this
petesafc
Postby petesafc » Tue Oct 23, 2007 5:45 pm
Mine was starting ok but cutting out whenever clutch was depressed. Changed camshaft sensor like I said and has been fine since. I shouldn't have said that should I?!
del2000
1.6 VVT ENGINE STALLING
Postby del2000 » Wed Oct 24, 2007 10:00 am
Anybody know why my car starts fine then cuts out after 10 seconds but when this happens there is a noise like a modem coming from the injection system (silver box righthand side of engine on the airline) I'm not sure if it made this noise before ?
1.6VVT
Users browsing this forum: No registered users and 87 guests
