key card
Posted: Mon Aug 20, 2007 8:55 pm
by onlydiesels
posted earlier that my keycard was working when it wanted,but has been ok for the last few days.now it has stopped working altogether and as i don`t have a spare,can anyone tell me how i can be sure that its the card and not a component on the car?
to start the car i now have to put the card in the slot,which is no great pain,but as you can`t lock the car with the keys in,i thought i`d try the following- sit in car with key in hand,o/s/f window open,reach out and press handle button to try to lock-NOTHING/DEAD.
sit in car,key in slot,window open,reach out to press handle button to lock it,LOCK/UNLOCK which is what i would expect,so if it`s the card thats the fault,why would it work the central locking when it`s in the slot? any ideas??
also,when the card is`nt working,how do i open the tailgate?
Posted: Mon Aug 20, 2007 9:30 pm
by cactusbob
You have changed the battery havent you?
Posted: Mon Aug 20, 2007 9:37 pm
by onlydiesels
changed the battery twice.just to make sure.
Posted: Tue Aug 21, 2007 10:21 am
by cactusbob
In that case, do pushing the buttons on the card lock the doors?
Posted: Tue Aug 21, 2007 4:55 pm
by onlydiesels
do you mean when the card is in the slot?
Posted: Tue Aug 21, 2007 6:47 pm
by cactusbob
No when it's not? There are two ways of locking the car with the wireless key. You can either push the button on the key or you can push the button on the door handle. Different antennas are used for each method
Posted: Wed Aug 22, 2007 10:22 pm
by onlydiesels
thanks for your replies,yes, i know there are the two methods,but if the card is`nt working,then obviously the buttons on the handle won`t work,what i really want to know is- IF THE CARD IS FAULTY REGARDS THE C/LOCKING,WHY,WHEN THE CARD IS IN THE SLOT,WOULD THE HANDLE BUTTON WORK IE.RAPID LOCK/UNLOCK???
Posted: Thu Aug 23, 2007 2:53 am
by silencer51
There are two different radiotransmitters in the card.
There's the hands free transmitter that concerns the locking/unlocking of the vehicle and then there's an RFID chip that is read when the keycard goes in the slot.
The most common failure is he card's radiotransmitter for the locking system.
On my car though it was the antenna on the UCH that failed and I had it replaced...
If the card does not work then to lock the car you have to manually close all windows (and make sure they 're closed!) and then open the driver's door, keep the 'lock' button on the center console pressed for around 5-6 seconds until you hear the locking sound and then get out of the car and close the door. If all has gone well all doors should be locked.
To get in you use the small key inside the card.
Posted: Thu Aug 23, 2007 12:45 pm
by m.bedforth
Warning - when following the above DO NOT shut the driver's door after pressing the lock button on the central console leaving the car keys inside and the dog in the boot. AA to the rescue and me red-faced.
