Where can I find th eengine code so that i can buy a Gates Compatible Timing Belt Kit.
The company tha tI am buying it from say it should start K9K but I can't find it anywhere
engine code?
engine code?
All information and/or advice given is in good faith and any action taken by the reader is done so at their own risk.
- IainMW
All the 1.5dCi's are K9K engines, I'm not sure that it states it anywhere on the car? But if you look in your drivers hand book it should confirm it there.
I would not expect Renault to specify different cam belts for the various incarnations of the 1.5 engine, but hey, this is Renault we are talking about!
Re: engine code?
sporttourer wrote:Where can I find th eengine code
It's should be engraved directly on the engine block, situated roughly 15-20 cm to the right (when viewing from the front of the engine) of the oil filter and probably obscured from direct view by a vertical water hose running in front of it.
And you may need to remove the cosmetic/sound-absorbing engine cover to see that area, but the cover should lift straight off if I've understood correctly.
Users browsing this forum: Bing [Bot] and 84 guests
