Hi Folks,
Recently jumped into the megane ownership world and i'm over the moon with my car..apart from the few little niggles we've had s far.
One of these was the horn. Basically it sounded like a wasp with some string quite tighly around it's neck. So i had it sorted under used car warranty.
A couple of questions that i have really.
1. Is the horn meant to be dual tone? If so, the replacemant wasn't when it was fitted.
2. Also, it has stopped working totally now, so i was going to have a look to see if the plug has come off, but i can't for the life of me find where it is.
It's going in next friday for the classic leaking through the near-side front speaker syndrome.
My car is a 53 plate 1.5 DCI 80 Dynamique, approx 55k on the clock and previously only owned by renault UK.
All help much appreciated
Regards,
Danny
Horn failure
- robznet
Hi Danny
The horn is only single tone on the Megane - and pretty poor sound wise!
It is located behind the front bumper/nose assembly and I think getting at it involves removal of the complete front section! - someone else may know another method but I doubt it!
I wish you all the best with your problem, let us all know how you get on resolving it.
Regards
Rob
Regards
Rob
- Currently Drives:: Badly
Yes it is a pathetic sounding item. And the others are right, I even removed the rivets holding the underside of the bumber to the whole bumper assembly to access it. I could remove the plug and get to the bolt, but could not undo it and gave up. Horn is just about smack behind the Renault emblem on the grille.
