new owner, one problem
Posted: Tue Jun 26, 2007 1:48 pm
by xcz_megane
hey just got a megane 1.4 16v on friday, and noticing quite a tremor through the steering wheel and pedals when hitting speeds of 60mph plus. any ideas? also after a look under the bonnet i have found a large pipe disconnected running from the battery area to somewhere else, it looks as though it should be connected to another part near it, it is a large, ribbed pipe if that is of any help! sorry for the bad descriptions, im a novice!
Posted: Tue Jun 26, 2007 1:56 pm
by Hoody
Hi there XCZ, the tremmer through your car may be due to the tracking or balancing. Try you local ATS to sort that out.
As for the pipe, it may be part of your air induction for the car.
This is just my opinion of what I would check first.
BTW, welcome to the club
Nick
Posted: Tue Jun 26, 2007 4:40 pm
by AlexB
Welcome to the club, xcz_megane!
My car is different, so can only suggest to look at the second link here:
https://www.meganeownersclub.co.uk/forum ... php?t=5167
Posted: Tue Jun 26, 2007 7:43 pm
by Jonault
Welcome to the forum.
If the car is second-hand I would assume that there is some wear already on the tyres which could mean they might need balancing.
The pipe you mentioned is the air intake. Follow it back and it is connected to a plastic box held in place by a bolt, the pipe coming out of the back of the plastic box leads to another plastic box between the engine and the bulkhead. This is the location of your air filter should you ever wish to change it, however the two screws that hold it together require a special tool to undo them.
John
