Hello all,I told you before in a previous post that I heard a hissing noise in the steering wheel and the guys at Renault diagnosed it as "Air bag spring coil" and they ordered it by DHL as they do have the regural one ,mine has cruise control.After they fitted this thing the hissing noise was gone but a new sound appeared which is a sort of friction between a metal and a plastic ,you hear it well when you are parking mainly when turning the steering wheel to the right,especially at the moment when you start to steer where the friction sound is max,they tried to adjust a bolt at the end of the steering column but with no success.they actually do not know what is doing this sound.I forgot to mention that I did the new bolt thing together with the 2 silicon pack for the clinging sound at full steering.
CAN ANYBODY HELP ME PLEASE????
Many thanks in advance.
FRICTION IN THE STEERING WHEEL NEED HELP PLEASE!!!
Hi there Hany
Mine makes exactly the same noise when putting a full lock on. So I took it to the dealers and as you can imagine, when I got there it wouldnt make a bloody sound.
It has been around 3 weeks now and until yesterday nothing, was out doing the old shopping thing last night and when I pulled into a parking spot at Tesco, here is the noise back. So I am going to get to the dealers on saturday morning.
Nick
Nick
Megane II 1.5 Dci Dynamique 3dr, Ottoman Blue, Private Registration, Sony GT30RN Head Unit, ShinyAutos.com Interior White LED Kit, 3rd Brake Light Cover, MOC Sticker
- silencer51
It must be the rotary switch behind the steering wheel (a.k.a. clockspring).
My car started making the hissing noise a few months before the warranty ended.
I had the part replaced only to find out that it also made a quieter hissing noise.
Since then I've had it replaced over 5 times and every part makes a noise of sorts, be it hissing or slight crackling when turning the wheel and the interior of the car is quiet.
Even the mechanics at my dealership admit that replacing it is not worth it, you may even get a switch thats more noisy than the one you have...
Thank you folks for your reply,now I understand as I did changed the rotary switch and the new one has a different sound like a friction,I will be going to Renault next Sunday to check it out,my car is under warranty,so should I try a second rotary switch.
The guys there told me it might be the steering column,any chance????
Users browsing this forum: No registered users and 92 guests
