How to Care for Plastic Rattan Set . Rattan is as beautiful as it is durable, so most rattan furniture needs only basic cleaning and care to preserve its natural strength and color. Follow these steps to keep your rattan furniture looking as beautiful as the day you bought it.
Not Too Dry
Natural rattan or cane furniture is essentially dried, dead plant matter, which means it is subject to becoming even more dried out and brittle in certain conditions. If used on a patio or porch during warm weather, keep it out of direct sunlight to avoid fading or brittleness. In the same manner, keep it away from heat ducts or an indoor fireplace. If the air inside is dry, a humidifier helps moisten the air enough to keep the furniture from drying out.
Not Too Damp
Much like dry conditions, overly damp conditions are not good for rattan. Extremely humid environments without ample lighting lead to a mustiness on the furniture, which indicates mold or mildew. Exposure to rain or wetness over time also damages rattan, so it is best kept indoors or in a covered, moderate location when not in use.
Keeping It Just Right
Basic maintenance such as dusting or a gentle cleaning keeps that rattan in peak condition. Dust it gently with a a feather duster when you notice dust, or vacuum it with an upholstery brush attachment for the main surfaces and a crevice tool for deep, hard-to-reach areas. A slightly damp, soft cloth wiped over the rattan gives it a general cleaning, while a bit of oil soap mixed into water, rubbed onto the furniture with a toothbrush, helps clean those stubborn spots. When you use moisture to clean rattan, dry out the piece in a well-ventilated area so it does not stay wet long.
Mold and Mildew Maintenance
A vintage rattan chair or furniture left in storage a long time may have a musty smell. Small specks indicate mold and mildew; wipe them away with a sponge dipped in equal portions of bleach and water, wringing the sponge out to keep it damp, but not soaking wet. A toothbrush comes in handy to remove stubborn mold or mildew. Wipe down the entire piece with a fresh damp cloth or sponge to remove any bleach residue, then allow the furniture to sit outdoors on a dry, breezy day. Repeat the cleaning process if the furniture still shows signs of mold or mildew.
If you are looking for a Rattan Corner Sofa , we can help. https://www.insharefurniture.com/produc ... -sofa.html can even help match the ideal Plastic Rattan Set with your garden.
Tips to Care Rattan Corner Sofa Set
Users browsing this forum: No registered users and 68 guests
