Hello al,
In a 2005 cc 1.6 model, the petrol pump looses pressure when engine is not running, almost immediately.
You need to press the ignition button multiple times, for the pressure to rise and the car to start. After starting, all is ok.
1. Do I have to replace the whole pump?
2. Until damage corrected, is there a way to “pre-pressure” the pump, like you can with cars with a key (you turn the key until ignition lights start, and you can hear the pump work for 2sec, before starting the car)?
Gas pump looses pressure
Users browsing this forum: Google [Bot] and 72 guests
