Megane cc 2011
Drivers door window drops to allow door to open on entry but when shut door window does not return fully to top and leaves 1 inch gap and cannot be moved with control button. After driving a quarter of a mile the window then closes fully.
Any ideas please?
Drivers side electric window not closing properly
Re: Drivers side electric window not closing properly
Suggest you replace the window regualtor. As you are able to close the window with good range of movement that this is an aelectrical issue reather than mechanical rigging.
Good luck.
Let us know how you get on.
Link to purchase a window regualtor is here: I purchased one from here recently. Very good.
https://www.ebay.co.uk/itm/TEMIC-FOR-RE ... 2749.l2648
Good luck.
2005 Scenic 1.9Dci 120 Exception
Thanks Husky_Dog
I've been Googling how to replace the unit and need to have a look at the door panel to see how easy or otherwise the job may be. I'm not the best DIYer. May need to get a garage to do it.
Thanks again.
Thanks again.
Users browsing this forum: No registered users and 98 guests
