Earthing Point
Danny01boy
Currently Drives:: 2008 Renault Megane
Earthing Point
Postby Danny01boy » Sat Jan 11, 2020 7:59 pm
Hi all,
I have recently hardwired a nextbase dash cam into the internal fuse box in the passenger footwell. To get it to work I need to earth it on some metal but cant see anywhere close apart from the door but this will trap the wire when the door is shut. Does anyone have any ideas when I can do this. Cant find any metal or anyway to feed it to the bonnet.
scooper1000
Re: Earthing Point
Postby scooper1000 » Sat Jan 11, 2020 8:21 pm
there is a good earth point just above the fuse box between fuse box and door seal..
PhilipC
Currently Drives:: 2005 Renault Megane II Dynamique 1.6L 16v
Re: Earthing Point
Postby PhilipC » Tue Jan 21, 2020 12:15 am
You can use an existing nut/bolt as there're a fair few tucked up away on the bulkhead.
TightFist9
Currently Drives:: Mégane mk2 1.5dci 2006
Fabia Greenline 1.4 DCI 2008
Re: Earthing Point
Postby TightFist9 » Sat Jul 18, 2020 2:24 pm
Hi, not sure if you're still about. Can I ask if you have a dab radio? I did the same as you, but the camera interfered constantly with the radio reception. Eventually had to take camera out. Did you have same prob? Thanks
