Rear Brakes
Lawrence
Currently Drives:: Mégane 2 1.5 dci
Rear Brakes
Postby Lawrence » Thu Jan 02, 2020 4:13 pm
Sorry if this has been asked before.
I have a 2008 RENAULT MEGANE EXTREME DCI (86), 1461CC Diesel, 5DR, Manual and need to replace the rear brake discs.
When I have looked online I am being offered ones with or without the bearings is there an easy way to tell which it is by just taking the wheel off so I can order the correct parts.
I would assume that it would need the abs ring as the car has abs
alanf
Re: Rear Brakes
Postby alanf » Fri Jan 03, 2020 5:16 pm
Just done mine came complete with bearings and magnetic abs rings
Lawrence
Re: Rear Brakes
Postby Lawrence » Fri Jan 03, 2020 6:39 pm
Thanks I just want to be sure I'm ordering the right parts
alanf
Re: Rear Brakes
Postby alanf » Sat Jan 04, 2020 9:37 am
You need to measure the diameter of the discs, I got mine from tinternet you give them your reg and they look up part, not always foolproof, if I can find site I will let you know
alanf
Re: Rear Brakes
Postby alanf » Sat Jan 04, 2020 9:44 am
Was from " clickamotorpart " found on ebay £82.15 for pair
Lawrence
Re: Rear Brakes
Postby Lawrence » Mon Jan 06, 2020 8:27 pm
Thanks for your help
