Oil Level
Oil Level
So this is a weird one. I have done an oil change, before I started the oil level showed half way between max and min. I emptied it out and got about 2.7 litres of oil out. I measured in litre bottles to make sure. I put 3 litres in and checked the dipstick again. It shows as massively overfilled, literally up to the handle. If you start the car it says oil level correct but I do not know if that would say otherwise if overfilled. I changed the filter as well so a small amount of oil was in that as well. The car itself seems fine I ran it for 10 minutes, no odd smells and its much quieter but the dipstick still shows as overfilled. I will leave it over night to see if its any different. I ought to add the engine was warm when I changed the oil. Any ideas?
Re: Oil Level
how you drained oil ?
Re: Oil Level
Sump plug left out until no oil was coming out.
- Currently Drives:: Renault Megane 2 1.6 16v Maxim
Re: Oil Level
I checked your profile and this shows your car as being a 1.6 megane. This engine holds 4.8 litres of engine oil.
Did you happen to check the level of the dipstick before dropping out the oil?
Re: Oil Level
All resolved, I was being a plonker the issue was human error.
Re: Oil Level
Maybe dipstick is wrong from diferent engine
