Hi all,
Replacing front bottom arms / wishbones on my Meg Mk2 and found the ABS sensor brackets which sandwich above the bottom ball joint to be rotten beyond repair. I've scoured this site and the net and not found anywhere selling replacements. This issue must be very very common indeed so I'm hoping someone who has "been there and done that" can offer a solution before I'm forced to go the hard route and make a pair. I've discounted breakers as I've just recovered two rad subframe support plates (mine were very rusty) and had to inspect many cars before I found a pair worth removing to refurb and re-use.
Front ABS Sensor Bracket Corroded
Re: Front ABS Sensor Bracket Corroded
Hi all,
Went ahead and made new Abs sensor wire brackets. Wasn't the hard route at all as quite easily made. Material cost me 2 quit, couple of holes, couple of bends, bit a paint and good as new. Sorted
Users browsing this forum: Bing [Bot] and 78 guests
