Drivers side window works randomly one day it works the next day it doesn't
barryhoney
Currently Drives:: magane mark 2
Postby barryhoney » Thu Jun 27, 2019 4:22 pm
Since I used the alarm cancle(press on and off button ten times )the drivers side window Will randomly stop working ,at the moment I am ripping my hair out ,not that I have a lot. I would just like to know if there is a known issue with this or have I got problems with the motor or power hope someone can help
noelo
Currently Drives:: megane sports tourer
Re: Drivers side window works randomly one day it works the next day it doesn't
Postby noelo » Thu Jun 27, 2019 6:44 pm
if you are handy with a soldering iron,put a layer of solder on all the pins on the window regulator (both sides)
this will give a good connection when plugged back in as the pins are now slightly fatter allowing the connections
on the socket to bite into the solder.
it solved my window problem
best of luck
barryhoney
Postby barryhoney » Fri Jun 28, 2019 9:06 pm
Thanks a lot will try that and let you know the outcome
noelo
Postby noelo » Mon Jul 27, 2020 8:01 pm
best of luck
Users browsing this forum: Google Adsense [Bot] and 38 guests
