Night lights don't work
- Currently Drives:: Renault Megane Scenic 2005 1.5DCI 105HP
Night lights, or the lights on the ceiling are the problem. Whenever I open any door, little lights on every corner turn on but you can't see anything in the car because they're just not too bright so you can't do things. I have tryed with 12 volts, on each little bulb, and they do work, but I think that little, let's call it hub, don't get 12v so the hole thing doesn't work. The same thing is going on behind the driver's seat. I have tryed replacing fuse for those lights under the steering wheel with no luck. That would be it for this time, thank you for your help in advance.
Users browsing this forum: Google [Bot] and 76 guests
