Hi all I drive a 2004 renault megane II 2.0 16v
Changed air filter, spark plugs and cleaned throttle boby then took it for a drive when engin got to normal driving temp the check injection massage came on and when revs goes to almost 3000rpm car starts to jurk. Took it to the local garage for diacnostic test "computer internal fault df038 fautl code". Can anyone please help me with this problem car drove perfectly before this.
Thank you
Check injection
- Currently Drives:: Megane MK2
Re: Check injection
I am having the same issue.
Going to take it to the garage and have a leak test done on the fuel injectors.
viewtopic.php?t=22749
Re: Check injection
so what happened guys ,i have the same problem,everyone has the same problem but it never gets rectified.
Users browsing this forum: No registered users and 63 guests
