Hello
I have a Megane 2003 1.6 16v
I need to know how much should open the dephaser solenoid
The one next to oil cap
I have the p0010 on obd
The car is starting good,no extra noises
I feel a power loss
Like it has missing horses
At idle ,when engine it.s wormed up if i press the gas pedal just a little but fast it goes down a bit the rpm then go normaly, only from 700rpm
If i do the same from 1000rpm or higher it goes up normaly
With engine cold it goes up straight away from 700rpm
I have checked the dephaser it has arround
8 ohm
At idle i read 11v
Took it out an plugged it to battery and it moves
but only arround 1mm
If i push it with something the piston moves all the way up revealing the entire hole
Is it normal to open just 1 mm when conected to batery ?
If somebody have a good one and wants to try it i would apreciate
Thank you
https://m.youtube.com/watch?v=7UlNy27CjGQ
Dephaser solenoid , how much should open ?
Re: Dephaser solenoid , how much should open ?
Is the opened distance ok ?
I hear a clicking ( sharp) on the right side of the engine
Any idea ?
Thank you
https://m.youtube.com/watch?v=h19vXNdmhfY
https://m.youtube.com/watch?v=tVOmBlQZh4k
Any idea ?
Thank you
With the engine warmed up
At idle
If i pinch the gas pedal
The timing advance goes to -10 then start rising
It doesn.t start rising from start
It stays at 0 at idle
At idle
Users browsing this forum: Google [Bot] and 114 guests
