When brake is pressed a warning beeps. The indicator also flashed fast. I found corrosion on back rear light. I cleaned it and indicator returned to normal.
Now just brake beeps when pressed.
BRAKE WARNING BEEP NOISE
- Currently Drives:: 2007 megane saloon
Re: BRAKE WARNING BEEP NOISE
Have you checked the brake fluid level.
Cheers.
Cheers.
Yes level fine but fluid is very dark black even
The system is a dumb system so the fact that the brake fluid is dirty / old should not matter, it only works on the level of the fluid.
Not sure what the beep can mean ?
Cheers.
Cheers.
Only happens on right turn with brake and indicator. Could it be a light problem. Right indicator was flashing fast found corrosion. I cleaned it and indicator worked fine. Now just there is just a warning beep when I turn right. Usually brake and right indicator.
Yeah I don't think you can rule anything out, make sure the contacts in the plug that connects to the rear light are all in clean condition and making a good contact.
Cheers.
Cheers.
Users browsing this forum: Google [Bot] and 71 guests
